To those using Trickflow intakes
i have the street heat but i think this applies to track heat users as well
1. i have studs, but nothing to tighten them with besides my hands.... how do i get those on tight
2. how in holy hell do the nuts get on the studs, becuase the way the intake is shaped makes it a royal pain in the *** to get the nut on, and even to tighten it is horrid.
3. PCV extension, the intake is a bit larger then stock and the rubber hose from upper to lower for the pcv won't reach, should i jsut hardware store it, and get a long enough hose?
I just finished removing mine this week a street heat the LT front nut i used a 12 point 10mm wrench the other 3 a 12 point 10mm socket with a swivel, is not that hard really, as far as the pvc hose just get a longer one not a big deal, one thing take the dist out it makes it easier good luck.
just that im building a motor on the side... and i don't think i can have the upper on the lower when i chain it up to the hoist. so i would have to put the intake on while its in the car and that makes life a bitch lol
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
