GOT IT!!!
if you order a timing chain make sure it has numerous adjustable key way sprockets in case you need to advance or retard the cam, as far as rockers go, I'd go with the comp pro magnum ones, 1.6, I assume you are stud mount 3/8's??? I upgraded to 7/16's
All,
Please take a minute to read the origional post on this thread. I value your opinions and feedback very much. I am going to start ordering parts tomorrow and i would appreciate it if some of your guys could steer me in the right direction.
Thanks again,
Bob
Thanks again,
Bob
Im going to buy them today, I have the shortblock the the heads w/ the 7/16ths studs and the cam, do i need anything special to install the cam into the shortblock?. I know i need:
A timing chain (what do you recommend?)
the RR's
Gasket set (felpro)
To start the degreeing process.
Is there anything else you can think of?
Thanks for your help,
Bob
the RR's
Gasket set (felpro)
Bob
CCA-1332-16 COMP Cams Pro Magnum Roller Rocker Arms
Rocker Arms, Stud Mount, Full Roller, Steel, 1.6 Ratio, Fits 7/ 16 in. Stud, Ford, Small Block/ 351W, Set of 1...
Today $285.95
This is it right??
Today $285.95
This is it right??
