FInally got the car started.... but it runs like crap!
Old 02-07-2009, 09:24 PM
kweb288
kweb288's Avatar
mk ill have to check all that out, going to be getting new plugs and regapping them.
Im also ordering a MSD 6al BTM ignition box
kweb288 is offline
Old 02-07-2009, 09:27 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
OK Kyle so you're running the same mass air as before? Where is it located in the piping?
PRO50SC is offline
Old 02-07-2009, 10:01 PM
kweb288
kweb288's Avatar
i had the 90mm lightning mass air all hooked up WAY before i put the supercharger on. The Mass air is the first thing the air touches, then goes to the power pipe, then into the supercharger, then to the throttle body
kweb288 is offline
Old 02-07-2009, 10:18 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
OK so now instead of it being in front of the t/b it's now located before the blower correct?
PRO50SC is offline
Old 02-07-2009, 10:20 PM
kweb288
kweb288's Avatar
yes it is
kweb288 is offline
Old 02-07-2009, 10:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Got any pics?
PRO50SC is offline
Old 02-07-2009, 10:55 PM
kweb288
kweb288's Avatar
the mass air is in the fender well
Attached Thumbnails FInally got the car started.... but it runs like crap!-2009-01-super-charger-040.jpg   FInally got the car started.... but it runs like crap!-2009-01-super-charger-036.jpg   FInally got the car started.... but it runs like crap!-2009-01-super-charger-037.jpg
kweb288 is offline
Old 02-07-2009, 11:10 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
All plumbing connections are tight correct? It could still be the mass air. That's why I went to a blow thru unit. However I had to work out the idle issue. It was a matter of clocking the mass air. But mine has been mounted in the stock location all along. Is the mass air supposed to work w/ the blower set up?
PRO50SC is offline
Old 02-07-2009, 11:27 PM
kweb288
kweb288's Avatar
ya its the same unit that they used on a vortech blower over at andersonfordmotorsports
ill have to go back and look at the conections, but i know something is wrong with the spark plugs because they are black as night, and the one i did take out was a lil wet/smelled like fuel
kweb288 is offline
Old 02-07-2009, 11:33 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Are you running an fmu and if so, is it set properly? What is the f/p set at?
PRO50SC is offline
Quick Reply: FInally got the car started.... but it runs like crap!
