help with cam on a 347 setup...
Old 02-08-2009, 08:18 PM
polo708
polo708's Avatar
Default help with cam on a 347 setup...
I ordered a 347 short block from fordstrokers.com along with a set of AFR 185cc heads. I also have a set of 1.6 comp cams rocker arms and a holly 760cfm carb from my blown 289. My buddy said I shouldnt re use my old cam in a brand new engine so I need suggestions on a new cam... It will be a street car first but it will see some track time also.
What cam do you recommend for my set up? brand and duration... thanks
polo708 is offline
Old 02-08-2009, 08:52 PM
Joel5.0
Joel5.0's Avatar
You could also go to your 347 short block order from fordstrokers.com, and add the item before the last one from the list, to have a custom designed to match your combo.
Joel5.0 is offline
Old 02-08-2009, 08:54 PM
ctgreddy
ctgreddy's Avatar
^^ i suggest doing that. thats what i did. jay allen knows his stuff and just like woody, has great customer service. but you should have no problem reusing a cam. as long as it doesn't look too worn out.
ctgreddy is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: help with cam on a 347 setup...
