Current build status
Guys,
Last Friday I picked up a fresh 306 shortblock and a set of AFR 165's (part #1404) with the 7/16ths studs, upgraded spring package and a custom ground cam from FlowTech. Today i purchased:
AFR Head Studs
Comp 1.6, 7/16ths stud mount RR's
Comp adjustable double roller timing chain
Comp Hyd roller Lifters
Head gaskets for AFR heads
Full felpro gasket set
I already have:
195LPH fuel pump
Aeromotive AFPR w/ Summit fuel pressure gauge in fuel rail.
MSD 9mm wires
MSD pro bullit dist w/ new cap and rotor
MSD ignition
new oil pan / pickup tube
new Ford Racing high flow oil pump
hardned oil pump shaft
MAC shorty's, MAC off road H and an SLP Loudmouth II catback)
What will be the advantage of getting long tubes vs the shortys i already have??
I know i still need:
Hardned Pushrods (I have a machinist coming to my house this weekend to degree the cam to make me a set of pushrods)
30# Ford Racing injectors
MAF (i have had VERY bad luck with Granatelli, open to all thoughts!! I heard ABACO was good ever heard of it?)
Starter (like to get a mini starter)
Water Pump (Hi flow / Electric??)
Alternator (upgrade to a 200 amp??)
Good set of plugs (What do you recommend?)
Can anyone think of anything else?? I really value your feedback and i want to get all the parts i need FAST!!
AFR Head Studs
I already have:
195LPH fuel pump
MSD 9mm wires
MSD ignition
Guys,
AFR Head Studs
I already have:
195LPH fuel pump
MSD 9mm wires
MSD ignition
AFR Head Studs
I already have:
195LPH fuel pump
MSD 9mm wires
MSD ignition
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
