fuel regulater
yea the best thing to do is just take off the upper intake the bolts are allen keys. with the upper intake off you should be able to change the reg. in 5 to 10 mins. you are going to need a pressure gauge whichi know u know already. but what type of reg are you runnin on the car? what size injectors? i have stock 19lbs injectors still and i am running about 40psi. i put my gauge in place of the shrader valve it was only about a 15 min job for everything to be put in have fun and good luck....
you could also maneuver the rail out of there. 4 bolts, couple fuel lines, and squeeze it out. Probably better off removing the upper intake though, so you don't damage anything
mrappe
09-26-2015 10:16 AM
