NO SPARK FROM COIL
Old 02-18-2009, 02:32 PM
  #21
ctgreddy
this coil worked fine before. and now it doesn't. so i borrowed one off of my buddys 87 and it didn't work. yet works fine on his.
ctgreddy is offline
Old 02-18-2009, 06:57 PM
  #22
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
so the coil isn't the problem then, is the dizzy installed properly??
mjr46 is offline
Old 02-18-2009, 09:45 PM
  #23
ctgreddy
i don't know how the dizzy could be installed wrong. even if i had it 180 off it would still cause a spark from the coil. which i'm not getting. I've talked to my instructor who is a retired master ford tech and he gave me a few tests to try, all of which passed. i'm completely out of things to try and will most likely tow it to a dealer.
everything i've checked so far.
checked power at stator.
checked power in and out of coil.
checked to make sure the tanish wire out of the coil "pulsed" when cranking.
checked power and grounds at ign module.
switched coil.
new distributor and ign module.
check to make sure my tach moves on cranking, so i've got tach reference.
double and triple checked all connections.
checked for continuity of just about every wire that is involved in the circuit.
unplugged capacitor.
unplugged spout.
checked all fuses in the system.
i have checked for continuity between the wire from the ign module to dizzy, that gives off the pnp signal. but I haven't checked to see if its pulsing while cranking since changing dizzy/ign module. will do that tomorrow.
ctgreddy is offline
firehorse02
11-16-2015 11:28 AM
Dathan
10-05-2015 05:52 AM
Sixer4Life
09-28-2015 07:05 AM
dalehunter
09-25-2015 10:51 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: NO SPARK FROM COIL
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
