h/c/i questions
h/c/i questions
OK so i have a 89 mustang 5.0 been planning a head cam intake swap little by little I've gotten parts so far i have some gt-40 heads, typhoon intake, tfs1 cam, now I'm trying for figure out the length of the push-rods i will need as far as i know the heads have stock springs and not planning to re-use the rods. I'm sure i will also need a new timing chain (double i believe) any suggestion? thanks
The only way to know what length pushrods you need is to check the length using a pushrod length checker. As for the valve springs you should upgrade them to something stronger if you're going to use an aftermarket cam.
i do have a push rod measuring tool i picked up from summit how would i measure by installing the cam first? and should i go with some trickflow springs since i have a tfs1 cam or something else? thanks im doing all the work my self so im learning as i go
trickflow or crane beehives for the springs,you'll be floating valves with that cam and stock springs
you need to get it all set up and bolts on the rockers with the adjustable in place,then rotate the engine by hand and check the pattern on top of the valve stem
