Valve Springs
Old 02-19-2009, 05:22 PM
mustangmike33
mustangmike33's Avatar
Exclamation Valve Springs
whats the max lift of the factory valve springs on the stock heads? a friend of mine is wanting to buy my cam out of my car, ( B cam ), and he doesnt want to change the valve springs. can he run that cam with the stockers?
mustangmike33 is offline
Old 02-19-2009, 06:37 PM
wowvfast
wowvfast's Avatar
he can...but always check
wowvfast is offline
Old 02-19-2009, 06:46 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
i couldnt on mine, valve float at 4k rpms. but doesnt mean it will happen on his, mine were just wore out. in order to use the cam to its highest potential, he will want to change out the springs with the correct ones. IMO he should keep his stock cam and mod something else. a B cam is hardly worth the effort of installing for minimal gains under stock heads.
FivePointOhh is offline
Old 02-19-2009, 07:35 PM
Portmaster
Portmaster's Avatar
If he doesn't want to swap the springs he needs to reconsider the swap
Portmaster is offline
Old 02-19-2009, 07:36 PM
Joel5.0
Joel5.0's Avatar
Allowing for a minimum gap from coil bind....... .450" lift ... IOW, he should upgrade them.
Joel5.0 is offline
Old 02-19-2009, 07:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
stock springs = stock cam
mjr46 is offline
Old 02-20-2009, 12:53 PM
mustangmike33
ok so heres another question for you. Portmaster suggested for me a little while back to upgrade my cam to a XE-274-HR Comp Cam considering my mods that im currently in process of finishing. now Tweak on here has the Nitrous Blower version of the same cam. the only differences are the duration and lift on the exhaust side. on the lift intake is the same at .555 but the exhaust is .570. ok so on my heads, they were pre-assembled using springs that were rated at .560 max. both intake and exhaust of course. i asked a tech at summit and he said im looking a 1/1000th of an inch. in his words. where my car is an auto. he wouldnt be worried about over revving, so i should be ok with those same valve springs. so whats the right things to do. if im gonna be ok with the ones i have then ill leave them alone, but if not i guess ill have to buy the right ones and sell my springs with the cam. so whats your alls input? oh and lastly. on his stock heads, if he changes the springs as well as the cam what kind of increase of power will he be looking at?
Old 02-20-2009, 01:08 PM
FivePointOhh
in limbo
10hp on the b cam. it made almost no difference at all with my car when it was stock. waste of time and money on a stock car.
on yoru car i dont know what springs you have but my money says its not double springs. when i called comp and CI, they stated for those extreme energy cams they require higher spring rate and seating pressure. which means double springs. like what i bought for my cam pictured below
for your car thats
Old 02-20-2009, 01:15 PM
mustangmike33
what cam did you put in your car? and did you buy a cam and lifter combo or seperate?
Old 02-20-2009, 01:36 PM
FivePointOhh
in limbo
using stock lifters. bought springs that match my cam. xe270-hr
i think your cam requires spring rate 360lbs+ i dont even think they make a single spring that high.
Quick Reply: Valve Springs
