buying the last parts for my 347 but need help!!!
Old 02-22-2009, 01:57 PM
canman87
canman87's Avatar
Default buying the last parts for my 347 but need help!!!
Im getting the final parts for my 347 so I can drop it in.
Im have 24lb injecters, 5.0L Tyohoon EFI intake, 65mm throttle body, & 65mm EGR spacer.
Do you guys think I should run a bigger TB and EGR spacer? But I already have those parts so would I really feel that much of a difference on the street... if i go to a 75mm?
what size mass air meter would I need if I run the 65mm or 75mm?
canman87 is offline
Old 02-22-2009, 02:22 PM
Portmaster
Portmaster's Avatar
Go Bigger
Portmaster is offline
Old 02-22-2009, 02:38 PM
canman87
canman87's Avatar
well what would i go with if i keep it how it is?
could i use a 73mm mass air meter that is for 24lb injectors or would that be to much for the 65mm parts i have?
canman87 is offline
Old 02-22-2009, 05:24 PM
ctgreddy
ctgreddy's Avatar
you could use that meter, and if you don't have the money for it you can wait to upgrade, but it is going to be hampering your power.
ctgreddy is offline
Old 02-22-2009, 05:33 PM
CobraJ
CobraJ's Avatar
I have a 75mm on mine, and I always think go bigger..
CobraJ is offline
Old 02-22-2009, 05:56 PM
grnstang
grnstang's Avatar
24 lb injectors? i think you might need to get 30's at least. what is your combination
grnstang is offline
Old 02-22-2009, 06:00 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ughhhh .......what heads do you have planned for it?? sounds a little like your choking the 347 based on listed parts above.
mjr46 is offline
Old 02-22-2009, 09:32 PM
canman87
canman87's Avatar
ive got a set of RHS (racing head service) 180cc runner 64cc chambers
no power adder
It has an AOD transmission that I had to totally rebuild. I bought the car with 4.10 gears but I’m going to put 3.73 in so it will be more street.
I put in brand new suspension: lower/upper control arms, shocks/springs, struts, and all new bushings.
I also have flowmaster that dump before the rear axel.
headman headers
anything else you guys need to know just ask
canman87 is offline
Old 02-22-2009, 09:38 PM
canman87
canman87's Avatar
cobra j you say you have a 75mm on your car... it says you have a 91 stroker... what all are you running with it
canman87 is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-03-2015 08:43 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
Quick Reply: buying the last parts for my 347 but need help!!!
