Speedo?
assuming this is for the car you have listed in your avatar, if its an 84-89 AOD trans you have in your car you need a the 21 tooth driven speedo gear. The 23 tooth is for the 4.10:1 gear ratio. If the AOD is from 90-95 then you need to change the driver gear inside the transmission along with the driven gear.
