Where can i find a computer?
How to Solve an EFI No Start ... hope he started the TS process by removing the ECM chip + checking for any EEC failure codes first.... specially any distributor's PIP signal issues. LUK
___________________
How are things in the service Adder?
___________________
Hey, thanks for popping in Joel... I wasnt sure if you still browsed this ****hole...
Things are going well for me. I'm doing a 2 week AT in virginia this may, and we are going overseas (projected) for 2011.
tuning a car has nothing to do with bolting parts on. I said tuning not installing. for the people that want to help. the computer works when it wants to for the most part. When the car starts you can test the power to the injectors and its all there but when the car doesn't want to start you can test and the injectors arent getting any power. The fuel pump works the car gets spark and cranks perfectly fine but the injectors clearly arent working like they should because the arent getting grounded out to work properly
