88 lx mustang probs!
Carbs run at about 6-10 psi of fuel pressure - any more than that and it will flood and dump fuel into the engine. Any car converted from fuel injection to carb MUST have a pressure regulator to drop the pressure or a different fuel pump that is set to deliver the fuel at a lower pressure. If the fuel filter has some air in it, that's normal. If it has A LOT of air, then there may be an air leak somewhere (like the pick-up in the tank, for example).
Could just air trapped in the filter. Take the fuel line off the carb and hold it up while you "fill" the line and filter with fuel or bump the engine over to pump fuel out the line so that the filter is full, then reconnect the fuel line and the filter should stay pretty full. I wouldn't worry about a little air in there, chances are there is another problem you should be focusing on. My carbed '67 Bronco w/351W would run great then start bogging down and I found it had a brass filter in the carb that was almost totally plugged up.
man ive ran into spark problems k im geting fuel i was barley geting any spark at all and so i put a new msd coil and igniton box got my alt check and it was flucuating volts and ams...so i bought a new one 2day put it on and now it want stay running even for a sec im about as confused and pissed as a person can get ive put over 500bux in new ignitoin from distrib to cap points condincer coil and box alt plugs and wires
yes point and condensor is def what im running and weve re gaped em cought less times man i was atleast starting last nite whn the old alt was on but the light on the box was flashing so that mean i was losing power and now whn cranking the light stays on but want hardly start mabey runs for a sec every 15 tries man
it be nice to know what issues this bad pony has i mean even whn a drove it with the miss it was fast and heck now it wan even start after 3 fuel pumps fuel lines filter a whole brand damn new ignition system from a to z im bought to give up!
