65mm to 70mm Throttle Body
I was watching Hot Rod TV and they had a '93 Mustang that they proposed like 8 mods that totaled less than $1,500 that will get an additional 50+hp.
I have a bone stock '93 5.0 in my '66 Coupe. I thought about getting a new 70mm throttle body. Does anyone know if this will work or do I need to get a new intake? Will upgrading to a 70mm give me a performance increase?
You do not need a different intake for a 65 or 70mm throttle body swap. Most guys with minor modifications will go with a 65. There is not a huge difference between 65 and 70 anyway.
Regarding the upper intake: I believe the stock upper intake opening is just about 65mm, so if you go with a 70mm, you will have some restriction unless you port match the intake to the TB.
