opinon's on the BBK SI-R ?
Thinking about getting it... any info on it over the trickflow?
also Does 95 5.0 motors have roller rockers allrdy i bought conv kit off ebay couple months back and not sure wheather my motor was hyd roller or roller i wanted make sure before i tryed do anything with them.
my cars in shop right now getting dual stage 2 clutch, b&m short throw shifter, ford racing 373 gears alum drive shaft put in BBK under drive pullies. and some other Random parts
My next things i want do is. the steed 19 Cam bbk si r injectors, mass air flow throttle body, better alt. to power all the add on's and some other stuff(im not sure yet wheather i want go with twin turbo or super charger.
but any info on what i need know would be great.
Daniel
Daniel
I'm going to assume you are using the stock heads as I see no mention of them, Yes you have a hyd roller. Get a better cam choice and use somthing like a TrickFlow intake. Before you go cam and bolt on crazy figure out what you want out of the car and build around that. What works well with N/A engines doesnt always work for boosted engines. The Steeda cam has a small base circle so longer pushrods will be needed.
A little advice to save you some time and money down the road, know what you have before buying parts.
Ok i say a set of AFR 185's, with 1.7 rockers, FFRP B-303 cam and a Trick Flow StreetHeat Intake, 75mm TB, 24lb injectors, BBK Shorty Headers/O,R H or X-pipe Flowmaster exhaust I have all the same stuff on my car and before my cluch took a S%$T I was running low to mid 12's, 12.1 with Drag Radals
Luke9222
10-22-2015 11:55 PM
JDWalton
09-24-2015 08:47 PM
