Backfiring and sluggish over 3k rpms/bad MPG
Old 03-08-2009, 03:31 PM
wowvfast
wowvfast's Avatar
please don't waste $$$ on cheap *** plug wires....you want the lowest ohm resist ones you can get, IMO
wowvfast is offline
Old 03-08-2009, 03:50 PM
BladeX10
BladeX10's Avatar
Originally Posted by mjr46
explain your set up ..is it a stock 84.5 mustang carbed set up???
Yeah. Its a stock 84.5 CFI with the exception of flowmasters
BladeX10 is offline
Old 03-08-2009, 03:56 PM
wowvfast
wowvfast's Avatar
holley or motorcraft carb?
wowvfast is offline
Old 03-08-2009, 04:20 PM
BladeX10
BladeX10's Avatar
I know it isnt a holley.. Motorcraft sounds familiar
BladeX10 is offline
Old 03-08-2009, 04:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's niether he said...cfi = central fuel injection = throttle body with two injectors.........on top of the throttle body, where the two injectors sit OP.....there will be a shredor valve, you need to hook a fuel pressure gauge up to it and check FP if it spikes high meaning past 35-40 psi you may have a bad fp regulator the fp regulator sits behind the two injectors on the TB
mjr46 is offline
Old 03-08-2009, 04:25 PM
mjr46
mjr46's Avatar
PS.......By now if it's been running rich the plugs may be fouled, so you may have to replace them too
mjr46 is offline
Old 03-08-2009, 04:46 PM
BladeX10
BladeX10's Avatar
It hasnt really been running rich.. Meaning that i haven't seen any black smoke or nothing. I pulled a few plugs and they all have a light tan color on the ends. I think its time to replace them anyways
BladeX10 is offline
Old 03-08-2009, 05:05 PM
mjr46
mjr46's Avatar
well if that's the case and your positive fuel pressure stays in spec at all times......then perform a tune up on it and retest = cheap and easy, after that if prob still occurs, 85 cfi has the ability to run a KOEO/KOER test and that'd be the next step to check for codes that may relate to a/f issues such as an o2 code
mjr46 is offline
Old 03-08-2009, 07:38 PM
wowvfast
wowvfast's Avatar
like a tbi....if it's like a chevy check the squirter...I have this problem on a buick with tbi
I have never seen a cfi....
wowvfast is offline
Old 03-08-2009, 07:58 PM
mjr46
mjr46's Avatar
It's not, no squirter on a cfi tb....all fuel mapping on a cfi is determined based on load calculations in the ecm that are determined by valuable input sensors such as the map/baro sensor, ect, act, and tps and 02 sensor
mjr46 is offline
Quick Reply: Backfiring and sluggish over 3k rpms/bad MPG
