How Do I Get My Engine To Start?
OK, my build is 100% done, however, I'm having an issues. The engine rotates (ignition and starter fires/engauges) but doesn't turn over/start. Any ideas, everything is hooked up, double, tripple checked all the plugs and their location on the distributer, so needless to say, I'm stumped.
Well I threw away all the old spark plugs and wires as they were pretty well toast, not to mention most of them broke when trying to remove them.
Now I had to unplug the fuel pump from this sensor thing in the trunk to purge the fuel pressure. When I plugged it in, I pushed the red button to reset the sensor, but is it plausible that it's stuck off, or bad?
An engine builders worst nightmare, lol
The engine rotates but doesnt turn over? Is the engine spinning over with the starter?
Have you checked for spark? Double checked the timing? Fuel pressure? Did you prime the oil pump for a few minutes? You are far from 100% done. Don't mean to sound mean I just don't want to see you ruin your engine.
ShaneB26154
35
03-04-2021 04:05 AM
KEM Motorworks
08-14-2015 10:13 PM
