Water pump bolts?
Water pump bolts?
In the process of removing my water pump to put in a HD Aluminum pump, i broke a few bolts, one of the shorter and one of the longer double sided bolts. I would like to replace all of them but if i can atleast get those two i'd be fine. Any body got any leads? cause i can't seem to find any, Anywhere...
When I replaced my water pump I took my original bolts to the closest Lowes and matched size and pitch. I then bought grade 8 bolts to hold everything together. I dont know if this helps mush but thats what I did.
The studs are a Motormite item available at your local Advance Discount auto Parts store.
http://www.partsamerica.com/ProductD...artnumber=2374
Part # 234744
If you have to go to Ford for the studs you'll want part # 388434-S2 stud for the long stud and part# 388432-S stud for the short stud.
Water Pump Bolts: Courtesy of 5spd GT
Here are some specs on the OEM fasteners, going clockwise looking at the
front of the engine, starting at the lower passenger side:
All threads are 5/16-18 pitch except for the stud portion of #6-9
which is 3/8-16
#1 Stud/Bolt, OAL 3-5/16, UHL 2.25
Bolt threaded 1", shank 1.25 (1 + 1.25 = 2.25" UHL)
Flange head .25", 5/16-18 stud thread = 13/16"
1 + 1.25 + .25 + 13/16 = 3-5/16" OAL
Drive size is 1/2"
Notes: This bolt/stud clamps the TCC to the block, retains the
timing tab,
and the stud retains the support bracket for the AIR pump,
accessory nut is 5/16-18, 1/2" drive (not a flange nut, but
could be)
#2 Stud/Bolt, OAL 3-1/16, UHL 2.25
Bolt threaded 1", shank 1 (1 + 1 = 2" UHL)
1 + 1 + .25 + 13/16 = 3-1/16" OAL
Drive size is 1/2"
Notes: Same as #1, but the shank is .25" shorter. This bolt/stud
clamps the
TCC to the block, and retains the timing tab. Stud may be unused
#3 Bolt, OAL 4-1/16, UHL 3-7/8
Bolt threaded 1", shank 2-7/8 (1 + 2/7/8 = 3-7/8" UHL)
Standard head 3/16"
1 + 2-7/8 + 3/16 = 4-1/16" OAL
Drive size is 5/8"
Notes: Clamps water pump to TCC and TCC to block
#4 Same as #3
#5 Bolt, OAL 2-7/8, UHL 2-11/16
Bolt threaded 1", shank 1-11/16 (1 + 1-11/16 = 2-11/16" UHL)
Standard head 3/16"
1 + 1-11/16 + 3/16 = 2-7/8" OAL
Drive size is 5/8"
#6 Stud/Bolt, OAL 3-7/16, UHL 1-15/16
Bolt threaded 1", shank 15/16 (1 + 15/16 = 1-15/16" UHL)
Standard head 3/16", 3/8-16 stud thread = 1-5/16"
1 + 15/16 +3/16 + 1-5/16 = 3-7/16" OAL
Drive size is 5/8"
Notes: Stud retains accessory, accessory flange nut is 3/8-16,
9/16 drive
#7 Same as #6
#8 Stud/Bolt, OAL 5-5/16, UHL 5-1/16
Bolt threaded 1", shank 2-7/8 (1 + 2-7/8 = 3-7/8" UHL)
Standard head 3/16", 3/8-16 stud thread = 1-1/4"
1 + 2-7/8 +3/16 + 1-1/4 = 5-5/16" OAL
Drive size is 5/8"
9/16 drive
#9 Stud/Bolt, OAL 6-1/2, UHL 5-1/16
Bolt threaded 7/8", shank 4-3/16 (7/8 + 4-3/16 = 5-1/16" UHL)
7/8 + 4-3/16 + 3/16 + 1-1/4 = 6-1/2" OAL
Drive size is 5/8"
9/16 drive
#10 Bolt, OAL 2-1/4, UHL 2
Flange head 1/4"
1 + 1 + 1/4 = 2-1/4" OAL
Drive size is 1/2"
Notes: Clamps TCC to block
#11 Same as #10
#12 Bolt, OAL 1-1/8, UHL 7/8
Bolt threaded 7/8", no shank (7/8 + 0* = 7/8" UHL)
Flange head 1/4"
7/8 + 1/4 = 1-1/8" OAL
Drive size is 1/2"
Notes: Clamps TCC to block (top, near intake)
#13 Same as #12
Ford studs use 5/16” on the engine side and 3/8” studs on the accessory side.
From Helmut Roner for timing cover/water pump bolts for no p/s and no a/c:
Lowes Hardware:
One 5/16 x 5½ inch @ $.47, Item # 55819.
Six 5/16 x 2 inch @ $.16 each, Item # 63319.
Three 5/16 x 4 inch @ $.28 each, Item # 63322
One 5/16 x? inch @ $. , Item # ?????
The last one I typed I don't have, yet. It should be 2-3/4 to 3 inches long. I bought a 2½ and not much of the threads go far enough into the timing cover. It's for the bolt hole that is between the two water ports on the upper left of the water pump. I'll have that info later tomorrow.
The bolts for the water pump pulley to be used without a belt-driven fan are 5/16 x 3/4 24-thread. The two rearmost cover bolts which bolt the cover to the block (not shown) are 5/16 x 3/4 inch. I am scavenging those from an ARP bolt kit that I have which can't be used with late model timing covers. Only a few from the kit could be used as the kit was designed for older model 289/302/351W timing covers._________________
Part # 234744
which is 3/8-16
Drive size is 1/2"
timing tab,
could be)
Drive size is 1/2"
clamps the
Standard head 3/16"
Drive size is 5/8"
#4 Same as #3
Standard head 3/16"
Drive size is 5/8"
Drive size is 5/8"
9/16 drive
#7 Same as #6
Drive size is 5/8"
9/16 drive
Drive size is 5/8"
9/16 drive
Flange head 1/4"
Drive size is 1/2"
#11 Same as #10
Flange head 1/4"
Drive size is 1/2"
#13 Same as #12
Lowes Hardware:
mrappe
09-26-2015 10:16 AM
jaiidutch
09-14-2015 10:29 AM
