CNC ported heads-347
#21
Regarding the cap and stud girdle issue: yeah, just put in APR main studs, use the stock caps, then find a good crank cap girdle. It goes on after the caps and helps to stabalize the lower end. You may need to use a deep sump pan tho. I don't mean to sound mean, but, if you don't know what a main girdle is you may want to pick up a few books and read up on the whole engine building thing. You don't need to worry about the bottom end till you cross the 450-500 HP mark, and by then you've picked up a lot of engine building tips. Or, you just learn the way all the old-timers have, build it, it breaks, build it again, only better. Fortunately, 5.0's are pretty cheap and are not irreplaceable.
when do the stock 5.0 blocks tend to be tempermental? as far as hp goes NA?
TfcCDR
09-14-2015 12:08 PM
