performer rpm 2 intake
Use a Thermostat housing with the NPT fitting in the top. You won't get a good reading until the Thermostat opens. You want the sending unit in the coolant. If you try to put a T on the intake you will have 2 false readings. They have to be in the direct coolant stream The factory unit is on the left front on the intake heater hose on the right front. You refer to the car as if you are sitting in the drivers seat.
zanemoseley
09-06-2015 12:58 PM
