AOD Question..
AOD Question..
First off let me say that i know nothing about an automatic transmission... I just bought a 91' 5.0 Coupe that is bone stock with an AOD in it. Got the car for real cheap and the seller said it needed transmission work. I am going to swap a T-5 in it eventually but for now was wondering if this thing could be fixed easily? The car is real clean and motor runs good.. Problem is when you put the car in a forward gear, it does not go forward!! Reverse works but kinda seems like i have to give it a little more throttle than it should take to get it to move.. Yesterday i was messing with it and put it in drive and it inched forward a little bit.. Kinda suprised me when it moved, so i gave it some gas and it moved about another inch or two.. Then i held it at about 4K and all of a sudden it grabbed and took off spinning tires in the grass.. I drove it around the block and it shifted and all pretty good, but still seemed like something was out of adjustment cause it took between 3k and 4k to get it to move at all from a stop.. Since then i have tried a couple more times and it will inch forward, but won't actually go like it did that one time.. Like i said before i am clueless when it comes to AOD, but someone told me they had a 5.0 thunderchicken that was doing the same thing and he adjusted a bolt on the side of the trans and it fixed his problem???? Well i am not betting on that fixing mine, but am willing to try.. What could cause my problem and what are a few things i can do to try and fix it?? It never made any abnormal noises, and also has way too much tranny fluid in it cause it leaks like a submarine with a screen door..
Thanks, Richard
Thanks, Richard
WOW..., I wish i can help but seams like your tranny might be gone? Try draining the fluid to see if there is any metal particles in. If there is than the clutch plates inside are toast! Just do the t-5 swap! it will be an easy weekend thing! Also not that it might matter but try playing with the TV cable on the side, sorry under the throttle body! the TV cable tells your tranny when to shift.
Well i bought the car about a week ago knowing that it had a messed up tranny so its cool.. I got it so i could put my motor and t-5 in it.. I thought it would be clutches also but if that were the case it wouldn't move at all, correct? I actually drove it around the block yesterday when it decided go forward.. But that is the only time i have gotten it to move. I was hoping it would be an easy fix so that i could stick it in my GT to sell.. Thanks for the help.
Richard
Richard
