why AFR'S?
RE: why AFR'S?
true.......i did forget about having to notch the pistons......so, forget tfs unless you wanna do a new set of pistons notched for tfs heads, or wait til you do a stroker or something to that effect if you ever plan on goin "all out" with it
RE: why AFR'S?
the afr's are the best bang for the buck,they come from the
factory cnc ported out of the box.edelbrocks are not
ported they are just cnc machined.out of the box the afr's
are the better head and you can do more with them.
RE: why AFR'S?
afr's are good heads...the only complaint i have about them is the weak valve package they came out with..
i bought mine the 1st month they came out...max lift is .544 and duration like mine 224/230 will cause valve float[:'(].....i will say this much i had ported/o-ringed rpm heads,and the hp gains was night,and day..... wish i dynoed to compare the two.... but it was a big difference.
RE: why AFR'S?
oh yeah i know a gut who runs 8's what's he have?.....BRIGGS&STRATON...LOL.!
it really boils down to what set up you have,and if it match's
ORIGINAL: dc_mann8
i know a guy with a NA 347 running 9.7x whats he have.. edelbrocks.
ORIGINAL: 86HOGT
Buddy at work has a N/a 306 running 10.8s. What heads does he have? AFR 185's...nuff said.
RE: why AFR'S?
these are good heads that you all mentioned. i think you can run the tfs-tw with 2.02 valves with out notching the pistons, something you can not do with the other heads. if you want a more race head you can run the tfs high port head but may require notched pistons, not sure on these. good luck.
