Electric Water Pump ??
Just purhcased an electric water pump, and with that i put on a new 2 row aluminum radiator. My fox is supercharged. I was gonna have my electric fan run the water pump. What are the thoughts, or do i just run 2 seperate switche?
I run 2 seperate relays both that are activated by switched 12v, that way I can run the pump with engine off for quick cool down times, I used a 30 amp relay for the pump as well as one for the fan= dedicate 2 seperate circuits to do the job
You can use the red wire going to the windshield wiper motor, it's hot all the time. There is a hot wire for the alternator also, but I don't use my stock alt. harness, only reason I said that. There are key on hot wires all over the engine bay and under the dash. Run the wires(small) form the key on wires to the relays. Two separate circuits. Run heavy hot wires from 12vt source to the relay and to the accessory you are powering. I have to 40 amp relays on my twin electric fans. A bit overkill, but it sure runs cool.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
