I need help with a few things... Pics inside!
Is that blue thing coming out of the firewall in the picture stock? or aftermarket?
Pics: http://i119.photobucket.com/albums/o...e/S6300204.jpg
Where does this go? and what is it?
Pics: http://i119.photobucket.com/albums/o...e/S6300205.jpg
Theres black "marks" on the ground where my exhaust blows.. Is that bad? easy fix? etc..?
Pics:
http://i119.photobucket.com/albums/o...e/S6300200.jpg
http://i119.photobucket.com/albums/o...e/S6300202.jpg
Sorry for the links. Thats the only way I know how 2 post pics..
Thanx
Pics:
Thanx
First pic- not stock, aftermarket firewall clutch adjuster.
2nd pic- pipe leads to the smog pump, assuming your probably not running one anymore.
3rd & 4th pics- carbon marks, car is probably running rich has some carbon build-up. Could just need a good tune-up.
The smog pump is still there.. with that not hooked up to the pump. Would that make my car stutter and spit at times!?!
OK! I thought that the black marks could be oil.. I checked my oil and it was low. It took 3 quarts to fill it back up..
Thanx
Thanx
Thanx
for a temporary fix get a BFH and just crush the line, then with some jb weld or similar get it nice and plugged....for a good way to do it cut it up and unscrew it from the back of your heads, then get a bolt that will fit ithink it was 5/8 but not sure right now
This is what I did 2 fix that problem temporarily..
http://i119.photobucket.com/albums/o...e/S6300206.jpg
Is that fine?
Thanx
Is that fine?
Thanx
