timing cover install alignment question
guys
when i put the timing cover on, is there any wiggle room to worry about so that the balancer fits properly inside the round timing cover crank gasket?
or once i bolt the timing cover on it will automatically be perfect?
thanks
thanks
Yes, there are alignment dowels in the block/timing cover that line everything up. Then the balancer will slide over the crank and into the crank seal. I suggest renting the install tool from Oreilly, Autozone, etc
i have been just putting it on using the crank bolt and washer.
http://www.autozone.com/autozone/acc...er=391373_0_0_
i didnt know there was such a thing. i will definitely pick one up from somewhere.
weird thing is i was just thinking the other day how severely screwed i would be if i stripped those threads in the crank.
thanks again
Autozone has them as loaner tools if you don't want to spend the money to buy it.
The kit they have includes the puller and installer all in one. Pay the deposit and then you get it back when you bring the tool back.
waid302
09-14-2015 11:19 AM
KEM Motorworks
08-14-2015 10:13 PM
