Master Disconnect Switch Setup
hey guys last year I put my battery in the hatch, and its now time to do the kill switch. For the battery I ran the wire under the car to the front. On doing the kill switch do I follow that same path to the front of the car??? also does anyone know where a good diagram can be found. I did not buy a kill switch yet or wire. I wanted to hear what everyone else did, like what brand, what size gauge wire did you use, did you run a different setup in the back? As for mounting the kill switch, I like the flip up license plate look. I saw it on the forums at one point. Im going for a legal setup for the track so it has to kill everything.
Thanks be4 hand.
87foxgt
Thanks be4 hand.
87foxgt
I find a diagram for you, but something important you should know. When doing a cut off you need to make sure that the alt. charge wire is able to go back to the battery after the switch is cut.
https://mustangforums.com/forum/5-0-...made-easy.html
This is where I’m at. I’m debating if I should move the starter solenoid to the back or not. I don’t know if it’s worth moving all the wires. And if so, should I run them the same path as the battery wire to the front of the car, which is underneath the car. Also I read somewhere that they ran the Alternator wire though the car to prevent damage from outside. This seems a little scary to me as there’s a lot of juice running though that wire. What do you guys think or do? As for the battery kill switch itself, I’m going with a 4 prong setup but I just don’t know what brand yet. I found the diagram for the NHRA legal battery relocation safest method using solenoid in the back. And here it is without moving the solenoid. Also here is a link to the PDF file for a 4 prong hook up.
http://www.speedwaymotors.com/FOUR-P...ITCH,6967.html
I plan on doing this sometime in the next couple of weeks so I’ll let you know if I have any trouble. I still like to hear what other people did if you’re up for shearing .
here's the links as the pictures are kinda small
http://home.comcast.net/~christopher...relocation.jpg
http://forums.corral.net/photopost/d.../mod3gwire.PNG
Last edited by 87foxgt; 03-22-2009 at 01:59 AM. Reason: The Pictures are to small to see
Otherwise what can happen is the remaining charged after cutoff will damage electronic equipment on-board.
I then ran a 4ga cable from my alternator through my firewall, and to the rear of the car where it goes to the battery side of the switch.
I disconnected my stock alternator charging cable from both the alt and the distrib. box. And I have since removed it from the harness
lincolnshibuya
12-08-2015 04:37 PM
1994, 50, alternater, battery, disconnect, dissconnect, hooking, kill, master, mustang, nhra, pic, pictures, switch, wire
