Welding SFC's
Welding SFC's
Im installing my MM full length sfc's tomorrow and was wondering if you guys stitch weld them in rather that running full beads. The instructions mention something about doing it on the front subframes but are pretty unclear. Thanks.
You can start out by putting some heavy tack welds all around. Then finish them by welding up all area of subframe connector that touches the subframe. You will want a full bead around the whole area, no stitching. Mine are fully welded also.
The car hasn't been on the dyno, but with a good tune im looking from hopefully around 300rwhp and high 12's. But back to the sfc's. One of my dads vendors he works with is a welder by trade and was saying they should be stitch welded in because a full seam could create a weak point where the material like the frame would crack next to the weld. He also said a stitch can be just as if not stronger than a seam. Im kind of torn cause there going in tommorow with some help so i dont know. Anyone else?
Stitch welding can be just as strong but full seams are better IMO. The gaps between the welds leave an area that can bend if enough torque is applied or the stitch spacing isn't done correctly. Just get them fully welded at any point where the sfc touches the frame and body.
Leave a half inch gap between every 2 inch weld. Fully welded makes the metal around the weld brittle. The gaps give it better strength because it has two differant hardness levels of steel. You end up with a spot that isn't pure brittle so there is some stretch. Now that said I doubt you ever to to the point where this becomes a factor unless you have the hoops reaching for the stars and landing hard. Full welds are better left for roll cages where you have exact thickness of mild steel or full chassis cars.
