86 mustang 5.0 302
Old 03-24-2009, 10:21 PM
briantlucas
briantlucas's Avatar
Default 86 mustang 5.0 302
Hi i have a friend just bought an 86 t top with a blowen motor he has a 84 ford f150 with a 302 in it just wondering what it will take to put that motor in the mustang? can you switch the intakes? can you just run the carb? can you run the fuel pump on the mustang? will we run into any computer problems not haveing everything hooked up? will we run into any trans problems not haveing the computer hooked up? thanks for all answers in advance.!!
briantlucas is offline
Old 03-24-2009, 11:16 PM
86 5.0L
86 5.0L's Avatar
first off the 302 in the truck has like 130HP, compared to the H.O. motor in the mustang(200HP)
you're better off finding a junkyard H.O. and sticking it in there
if you want to try swapping, you'll need to replace the cam and intake, and im sure theres other stuff missing
86 5.0L is offline
Old 03-25-2009, 07:24 AM
86HOGT
86HOGT's Avatar
Absolutely, best to find another HO 5.0.
86HOGT is offline
Old 03-25-2009, 12:14 PM
briantlucas
Ok thanks alot what is the diff between the two motor i mean what is in the HO to make it a Ho?
Old 03-25-2009, 12:19 PM
mustangsneverdie
mustangsneverdie's Avatar
it has a different cam and I think the comp. was raised a little and the H.O. block is hyd. roller and timing is like a 351
mustangsneverdie is offline
86HOGT
86HOGT's Avatar
Yes, but the 84 and older HO aren't roller.
86HOGT is offline
Old 03-25-2009, 12:23 PM
mustangsneverdie
oh yea I didn't notice that the op said 84 model f-150
Old 03-25-2009, 12:24 PM
briantlucas
so then are the block iterchangeable? probally the best thing to do is pull the motor out of mustang and just build that one
Old 03-25-2009, 12:26 PM
briantlucas
yea the other motor is a 302 out of a 84 ford f150 and i know it is not hard to make 200hp either just trying to figure the cheapest way out
Old 03-25-2009, 03:57 PM
PJC Racing
PJC Racing's Avatar
Is the 86 carbureted or fuel injected? If it is fuel injected the cam in the 84 will not work with the EFI it has a different firing order, meaning the injectors will be operating at the wrong time. The 84 block is NOT a roller and the 86 is a roller. To just to get it running you could use the 84 as it is, if the 86 is carbureted. You could still use the 84 with the EFI if you swapped out the cam for a stock 351 FT cam. Now the 84 will be severely down on power due to the low compression. Personally this is something I would not do. Like it was said before, your best bet is to tear down the 86 block find out what is wrong and go from there.
PJC Racing is offline
Quick Reply: 86 mustang 5.0 302
