guys running carberators
Old 03-28-2009, 09:59 PM
worm2500
worm2500's Avatar
Default guys running carberators
what type of fuel pickup are you guys running...modified stock pickup, aftermarket pickup, or sumped tank.
I am thinking about buying a aftermarket pickup, but I heard they could suck air because of the baffles in the tank. I was just wondering what you guys are running. and if you have had any problems with running the pickup. I really don't want to spend a ton of money on a sumped tank, even though they look bad ***.
thanks
worm2500 is offline
Old 03-28-2009, 10:26 PM
mstngsule68
mstngsule68's Avatar
stock efi pump
mstngsule68 is offline
Old 03-28-2009, 11:06 PM
tinman
tinman's Avatar
I'm using an aftermarket fuel cell with a sump in it.
I've heard of lot's of folks just using the original EFI pick-up.
Don't try to use the EFI pump,way too much pressure. Holley 'blue' pump with the regulator set to about 5# pressure will work good.......
tinman is offline
Old 03-29-2009, 01:30 AM
mstngsule68
you can run the stock efi pump perfectly fine no problems what so ever, im doing it........ just gotta know what to do.... if someone would actually hook the pump straight to the carb, then they deserve to blow the bowl's right up lol, but yea theres alot more options if you have money
Old 03-29-2009, 06:47 AM
Portmaster
Portmaster's Avatar
Here ya go. Depending on the power of your car as to how large a fuel line you need. I reduce mine from -10an to -8an. They won't air unless you olny have just a gallon of gas left in the tank. A sump is the best way to go for running a low fuel level and hard launch But I don't want that ugly crap hanging down under the back of this car. I want it to look like a street car. I always run with at least 3/4 of a tank of fuel anyway.
http://store.summitracing.com/partde...=GRN-GM-TI7998
Portmaster is offline
Old 03-29-2009, 07:56 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
i just took the stock efi pump out and added in a rubber hose thats the same length, no problems at all.
projectresto83 is offline
Old 03-29-2009, 08:02 AM
Portmaster
Portmaster's Avatar
Mine had a 5/16 line going in. It wouldn't have worked with my engine, lol
Old 03-29-2009, 11:22 AM
holyshift
holyshift's Avatar
How many regulators you been through???...and dont lie..oh and Worm....iam diggin the Earth Worm Jim.....lol
holyshift is offline
Old 03-29-2009, 02:28 PM
worm2500
worm2500's Avatar
guys i just bought a used Granatelli pickup on ebay for 60 bucks buy it now. i think i got a pretty good deal. So did you guys just cap off the return line or what?
worm2500 is offline
Old 03-29-2009, 02:32 PM
mstngsule68
Red face
this is the second time ive ran the same set up, never went through a reg. still on the same one for this time, and never went through one on the other either, why do people always think it wont work.
Quick Reply: guys running carberators
