need help on cam size!!
Hey, I just came up on a smokin deal with a roller 302 that hasnt even been put together yet. It is a 91 block with forged inernals but with stock bore, Edelbrock aluminum heads Gear drive and well the cam the guy said it was the second one from ford racing. The guy planned on having it smog legal for his mustang, But now im going to stuff it in my 62 ranchero so my question is before the machine shop assembles it next week i want to know what is the biggest size cam i could stuff in that motor without clearence problems. Im going to the machine shop tomorrow to see the number on the cam it has now.
You would need to know the type of piston, Valve size. You are headed in the worng direction already going to the bottom of the page cam right out of the gate.
Oh, and i still need to buy roller rockers so any suggestions will work.
The pistons are pro power flat top. The heads are performers with 2.02 valves. Im going tomorrow to get the full specs on the parts that are going to be installed.
bigger isn't always better nor does lift define if ptv will occur, it's a matter of valve timing events
Yeah I was just tinking about having a little more lope for the ranchero. I think the one it has now is the e303 cam does that have a pretty good sound?
if you want lope put an f-303 in it
there are a lot of shops that make custom cams specifically to the parts you have on you car or are putting in...
hard to find the right grind on a custom cam unless you really know your stuff.lol
Originally Posted by Slayer420
(Post 6081367)
