What size bolts are needed?
5/8-11 IIRC.
Trick flow sells them as TFS-51400265
http://store.summitracing.com/partde...0&autoview=sku
This might be some help to some of you who go to plug the holes with bolts and run into the same problem I did. My holes were so clogged with soot that I couldn't get the bolts to thread in. So I came up with this alternative solution.
Here is a pic of the back of the head and what the holes look like.
I cut small plates out of some 3/32 steel I had laying around to roughly the same shape as the gaskets that connect the smog tube to the heads.
Then I drilled small holes where the little bolts go that hold the smog tube in place.
Here's a pic of the passenger side installed... you can see it in the mirror I'm holding. I used a little rtv on the gaskets to make sure they don't leak.
