serpentine belt
all im running is the crank water pump alternator and tensioner. anyone know what the belt size is?
I can look tonight when I get home and give an exact size. I am running the same setup. I just cant remember what it is.
That would be great thanks.
Make sure you save your recipt, you may need to go up or down a size. There is usually a slight variance, as was the case when I put an a/c delete(exact same as stock brackets) on my fox and the stock non a/c 5.0 belt did not fit.
I am wanting to think its a 53 inche belt for some reason but I will find out for sure later.
With stock pullies it a 57".
With underdrive pullies its a 53" |
weird... mine is 44.5"
well i guess ill start with the 57 and see how that works. thanks.
Take a piece of wire, wrap it in the correct fashion. Measure it, subtract half inch. You will be pretty close at that point.
