84 not wanting to start
Alright.. My car has a new problem. Whether its hot or cold.. the car wont start.. Itll crank then itll start skipping and start to fire but it wont start. Once in a while itll fire up and when it does the car runs fine with no problems whatsoever.
Now my battery is dead from cranking so much. lol
Anyone know whats wrong?
i got a cfi.
Ill explain in alittle more detail on what it does.
When i turn the key.. It cranks for 2-3 seconds like every other car does.. Instead of it starting.. Itll will then start to skip and you can hear the motor start firing but it wont be enough to get it started. It will eventually grab on and start if i try it a few more times. It just started happening too. Its getting fuel. I'm sure its got spark too if it starts up and runs fine
don't assume it's getting enough fuel!! you need to hook a pressure gauge up to it and see what the fuel pressure does in the koeo mode...does it reach proper pressure and hold or does it drop off ect ect...on top of the throttle body where the two inj are located there will be a schredor valve/ test port, utilize it
ShaneB26154
35
03-04-2021 04:05 AM
jpplaw
08-22-2015 09:29 PM
