biggest cam or best cam for a pretty stock 302
hey i got a pretty stock 302 the only thing really done to it is its punched out but not stroked or nething. i am putting a cam in it and i want the most out of it as i can until i get new heads. wut should i use or look at mind you this is a kind of budget car but still want good ****
you can put a B303 cam in your car without changing anything. but the b cam is a tough idleing cam. if you have an auto. it will wanna pull through a redlight with a stock torque convertor. but i took a b cam out of my car and sold it to a friend of mine and he put in his car with stock heads, springs, retainers, locks, etc. it works fine. i mean every car is different but imo, youd be fine with a B cam. maybe an e cam but not sure.
cam swap = spring upgrade , no if's ands or buts, for you guys who don't and think your rides are reaching the full rpm potential and that valvetrain is kosher, then you are clueless and have a lot to learn, stock springs are barely capable of supporting stock cam, go ahead and put a heavier spring on the stock cam, see what you achieve, the results may suprise you. but if you wanna use a b-cam with stock springs just to say you have a b-cam and a lumpy idle, go for it, cause that's all you'll have.
you gotta replace the springs with any cam you go with. ANY!
i had a B cam with stock springs and for a while it would pull to 6k but shortly after i had valve float and couldnt get past 4krpms. replaced the springs and got now i have a lumpy idle, little extra performance...but mostly a lumpy idle. LOL!! hence how i now have a comp cam xtreme energy. gonna make this ol' girl scream!
