The Teardown Started Tonight...
Old 06-19-2005, 06:56 AM
91hatchgt
91hatchgt's Avatar
Default The Teardown Started Tonight...
I have everything that I needed, So I ripped it all apart.. I started late tonight and I got it down to the bare block, and painted my valve covers. Tomorrow morning, all I have to do is throw in the cam, and adjust the roller rockers on the new AFR heads! It should be done by lunch time tomorrow...
For those of you that dont know:
I just got:
-AFR 165cc stud mount heads
-Hardened pushrods
-Crane 498/498 220/220 Roller Cam
-Scorpion 1.6 Roller Rockers
-ARP fasteners
91hatchgt is offline
Old 06-19-2005, 09:40 AM
Black Snake
Black Snake's Avatar
Default RE: The Teardown Started Tonight...
Good luck.
Black Snake is offline
Old 06-19-2005, 10:53 AM
stanglx2002
stanglx2002's Avatar
i hope everything goes well and take your time and make sure you have everything tight so you dont get any leaks
stanglx2002 is offline
Old 06-19-2005, 11:27 AM
87mustang347
87mustang347's Avatar
damn another project gower here on the forums. lets see if u can get that thing back on the road before OB can[sm=gears.gif]
87mustang347 is offline
Old 06-19-2005, 11:30 AM
Tims 88GT
Tims 88GT's Avatar
sounds good, have fun, and it should run really good when you get it back togeather.
Tims 88GT is offline
Old 06-20-2005, 01:19 AM
91hatchgt
91hatchgt's Avatar
Yep it was a two day ordeal.. It runs a lot better than it did, and sounds great, but I think the stud mount rockers aren't adjusted correctly..
I was told to: Turn the engine with a wrench, when you see the intake valve begine to open in one cylinder, adjust the exhaust valve by snugging the bolt (about 1/2 turn) and then locking the allen bolt inside. (Poly locks) Then do the same thing, just with the opposite valve. and of course repeat the process for each cylinder.
Does anyone know exactly how to do it, or a site that explaines the process? Thanks..
Old 06-20-2005, 01:24 AM
crazyhorse
crazyhorse's Avatar
good luck hatch. what length push rods did you get ?
crazyhorse is offline
Old 06-20-2005, 03:07 PM
91hatchgt
91hatchgt's Avatar
ORIGINAL: 91hatchgt
[sm=feedback.gif]
Old 06-20-2005, 09:13 PM
88mustanglx
88mustanglx's Avatar
i wish i had money to do that but $200 a week doesnt seem to be cutting it.
88mustanglx is offline
Old 06-20-2005, 10:37 PM
silver91gt
silver91gt's Avatar
ORIGINAL: 91hatchgt
ORIGINAL: 91hatchgt
[sm=feedback.gif]
your rockers should have some instructions for adjusting the valves.
silver91gt is offline
Quick Reply: The Teardown Started Tonight...
