How to add nitrous to boosted application??
So I've got a '95 Mustang GTS, I have it pro-charged and decided just tonight that I want to hook my nitrous back up to it. What's the best way(wet,dry,...) to hook it up and hook it up so that it won't leak under boost(~15lbs.) ((I'm going to have it professionally tuned once completed)) I have a dry kit sitting around here somewhere, so I have a few solenoids, lines, tanks, electrical etc, so buying the wet kit conversion would be an ideal option but I'm open for more suggestions. If you have any please let me know, or if you know anyone who has done it, again, please let me know lol. Thanks.
If it were me, I'd run a wet kit. You are already under boost, which requires a boat load of more fuel. No sense in trying to add to the already problematic equation of detonation in the cylinders by introducing more oxygen and less fuel. Use the wet kit and you will be fine, untill you reach the blocks limits and then BLAMMMOOO. Wished I would of not done that feeling will probably start to overwhelm you.
No, no engine hoists yet. I remember Samseed was doing it, but I don't remeber how. He ran his factory block into the low tens if I remember correctly. Thats my goal right now, I want to push my factory 5.0 to the max.
You can go wet or dry.. I went both on a two stage. The dry stage was a small shot that actually sprayed across the MAS. Then the second stage was the wet kit. It was a low boost though.
but anyways... if you have a dry kit just do it dry, you only need about about 50hp jets to equal about 100 hp gain , by squirting with the blower your getting a triple effect in a sense
precooling the intake charge, freezing the intake , and adding more 02
the first are technically the same thing, but w/ the blower you have added heat, so imo it is different since an NA gets a double effect (cooling + 02) see what i'm saying ?
anyways... just my thoughts... as long as your injectors aren't maxxed out, the dry kit will spike FP to 80 and make full use of the injectors capacity.. it will also inject the fuel where it NEEDS to be... in the combustion chamber... instead of the upper intake where it pools up on the rough casting turns so you can try and make it ignite if something fails
jwog666
12-27-2021 08:09 PM
