USED AFR 165 HEADS (ON BUDGET)
a few have done it this way...listen.
a 347 stock block
10.5 compression (i think..it's lower)
canfield heads 195cc
custom cam
vic jr intake
pro systems carb
1 3/4 george klass(accufab) headers 3 inch exhaust
he made over 500 rwhp/tq drives it daily
a 347 stock block
custom cam
vic jr intake
pro systems carb
door stops usually work lol!
i had 185's and i sold them for $800 with upgraded springs,and some mill work/clean up..
a good set of alumnium heads are out there,but after you make them right...wouldn't it be better off in getting a brand new set of heads that are set up right?
yes i sold used,but i'd be leary of buying used in some cases where a seller might not be honest.
A set of AFR 165's will flow 250 CFM right out of the box. There is no comparison between the two heads. Also the combustion chamber and alloy of the AFR is so superior that you can run a full point of compression more with the AFR over the E7
