buildin a 302 lookin for a power estimate
There is no way you can put identical parts in two identical engines and get such vastly different numbers unless one person is an idiot and the other isnt. Its just not possible.
2+3= 5
not
2+3= 3 to 7
Granted used engines can differ somewhat, but you wont get 40-50 hp difference unless something like a blown head gasket, rings that arent sealing, timing is way off, a:f is retardedly off, bad vac leaks, **** like that. Generally you'll know if one of the failures is causing you problems, and with a computer controling the timing and a:f its pritty hard to get that wrong. So to me its pritty impossible to see how two identical efi cars can have such a disparity. I hope you can explain away my confusion.
2+3= 5
not
2+3= 3 to 7
253rwhp
that was before the megasquirt, also I should have said "stock-engine cobra"
last count I think he was at around ~260
dude i was just looking at your cardomain page..those numbers seem really low for your setup. i think you should go down to at least a 70mm TB. How come your tuner cant adjust how rich your car is running?
bradleyb
11-27-2015 07:50 PM
09-25-2015 06:58 PM
