WHAT INJECTORS DO I HAVE?????
The only pink ones I've seen are the newer style and are 21# for a Navagator or 5.0 FFV Explorer.
http://www.fiveomotorsport.com/Parts...InjectXF1E.jpg
http://www.fiveomotorsport.com/Injector_SetsFORD.asp
There are companies out there with flow benches for them but I don't know how you would do it at home.
You would have to have them hooked to a working 40psi system and see how much fuel they flow into a container for say 30 seconds. weigh it up, then mutiply that number by 2 then that number x 60 to gel lbs/hr.
So if you got 0.1583 lb of fuel then x2 = 3.166 x 60 min = 18.996 or 19lb/hr.
Or you could send one here to see what it flows, if big enough, you could do the other 7.
http://injectorrx.com/
