Fuel Injector
Old 04-27-2009, 09:39 AM
chosen1_39
Default Fuel Injector
Will a bad fuel injector cause a car to have a miss, I have a 87 5.0 basically it a street car everyday back and forth to work kinda car, but will clown if need to, what I'm asking if an injector would cause a miss when replacing those injector which injector will be the best for the money. In search of the miss I've changed wires, plugs, rotor, checked vacuum hoses, someone says its running rich in the fuel try replacing injectors so thats where I'm at.
chosen1_39 is offline
Old 04-27-2009, 11:41 AM
86HOGT
86HOGT's Avatar
How many rounds are on the engine? It's very possible. With a factory intake it'll be hard to pull the driver side injector connectors one at a time to test if it is. If you pull the injector connector while it's running and the miss stays the same, it's that injector, but they should really be replaced all at once. If you're stock, use 19lb/hrs....
86HOGT is offline
Old 05-14-2015, 09:55 PM
C~Dwhited22
I have a 95 mustang what would cause the exhaust be so rich i cant seem to get the right levels
C~Dwhited22 is offline
Old 05-15-2015, 06:22 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum, but you should start a new thread when you have a question or looking for advice. And be as detailed as possible when explaining your problem, and some details about your car. That way we can give you accurate advice.
Also, explain in the new thread why you think it's running rich and how your checking those levels.
88 orangepeel notch is offline
Old 05-16-2015, 04:04 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
how do you know it's rich?? your nose??..lol if that's the case that's not a good method to verify.
mjr46 is offline
GimpyHSHS
03-12-2018 04:16 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
4cylinderplus2
09-30-2015 05:26 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Injector
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
