What to look for when pulling oil pan?
Old 04-27-2009, 11:11 PM
chazmcgee
chazmcgee's Avatar
yea its there.
chazmcgee is offline
Old 04-28-2009, 11:53 AM
chazmcgee
chazmcgee's Avatar
well as of now i can take engine out ship it back and they will look to make sure there is no mod to engine to cause this, then they send me a new engine(or my engine with a oil pump on it) or they will pay for parts which im about to order from summit and if that fixs **** its all good, if not i send back the engine then they send me a new engine.
Im going to fix it but i dont want to pull the engine i could easily but this is my current plan:
Put the car on four jack stands in the air, to get my big *** under there.
Put a jack under the rear end pumpkin for a little extra support
Put a jack under the tranny, undo tranny mounts and engine mount nuts
I already unbolted the headers.
Using the engine lift to pull the engine up to create space to take off the oil pan do some inspecting putting another oil pump on and what not.
Does this seem doable from underneath?
Old 04-28-2009, 12:40 PM
keek89gt
keek89gt's Avatar
just unbolt the motor mounts, the back k member bolts and take out the rack....no need to unbolt the tranny, just jack the motor up as high as possible and it should come out
keek89gt is offline
Old 04-28-2009, 06:18 PM
chazmcgee
chazmcgee's Avatar
Do i have to undo the rack and pinion or does the k member drop a considerable amount?
how many bolts should i be looking for on the k member? I never took the k member before
Old 04-28-2009, 07:13 PM
1988TTOP
1988TTOP's Avatar
i was able to drop my oil pan with just unbolting the k member there is 8 bolts if i remember right
1988TTOP is offline
Old 04-28-2009, 07:26 PM
chazmcgee
chazmcgee's Avatar
i think imma go ahead and just pull the motor so i can have a good look and decide if i want to send engine back or keep it if nothings wrong, ill post pics on here and get yall opinion though.
chrisdbassplayer
10-13-2015 06:53 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: What to look for when pulling oil pan?
