WINDAGE TRAY
Why are you putting a windage tray on? The engine doesn't turn enough rpm if it's stock to even need it. As far as fitment, my Canton tray was setup to bolt on to the girdle, the pickup tube barely touched it, so a bit of tapping with a plastic hammer fixed it. As far as the oil pan hitting the tray, you'd need a bigger pan. Again, I run a canton stock replacement pan, but it's designed to sit lower.
haus85z
04-02-2006 10:15 PM
