KOER test, codes, and i couldnt get KOEO to work? help.. ( lean car )
So heres my story.
A) Tried to run a EO test today, and i got like 5 really random lights, not codes at all. I was confused, and trust me i checked the setup for an hour.
So i moved on, and ran the ER hoping id have some luck. And it worked! I got these codes:
21
41
91
So, ( im not lazy i looked them up )
21. ECT Sensor Out Of Self Test Range. 0.3 to 3.7 volts
41 - System Indicates Lean -passenger side
91 - o2 Sensor Circuit Indicates Lean -driver side
B)So, the first one, i have no idea what that sensor is, so please help.
And clearly i am running lean, i thought id check too, pulled a plug, it was pretty white. So yea, shes lean.
C)So wtf is that first sensor. And more info, i ran the ER test again, and didnt get the 21 code. Only a 41 and 91 again. Soo whats the deal there. The battery wasnt the normal one in the car, so it may have been a connection issue with the batt.
D)Also, how do i fix this lean issue. And for the love of god, do not say vacuum leak, my car has an idle roll ( which i was hoping to solve with this test ) and i have checked everywhere for a year ( random times ) for different vacuum leaks.)
E)So if anyone has seen a 41 and 91 alot, and knows what usually fixes this, please feel free to add some input!
Once again, thanks guys!!
21
41
91
it runs awesomely !! umm i have brand new o2s when i put in the o/r h pipe.
would it be benifitial to take out the smog pump? any chance i have a vacuum leak in the the smog system? i am considering taking it put.
thanks
thanks
just because your car shows those codes doesn't mean the car is running lean. It means the sensors are getting lean voltage.
Open your hood and look to the left of the distributor. There is a metal pipe that turns down into your intake. The sensor that is connected to that pipe is your ect. You cant miss it and will need maybe 2 wrenches and 5 minutes to replace it if needed.
