STUPID ABS LIGHT!!!
It is on probably cause you had a dead battery or had the battery disconnected for a long period of time.
More info about 94+ airbag systems: http://www.veryuseful.com/mustang/te...95.html#CODE12
1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
2. Cycle the ignition switch to OFF and then to RUN.
3. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
4. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
5. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
6. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
7. Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Ahh ya mis read it. sorry. But like Mjr mentioned there is another test connector with a red cap on it and I think it does say abs on it. Stupid question did ya make sure the brake fluid was full and make sure the connector is pluged in to the brake resivor.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
