302 28oz to 50oz ballancer
I have a 1980 302 and I am putting a new t-5 into it. I have all the parts now, but I believe I have another problem. I have a good used 50oz flywheel for the tranny and the engine has a 28oz harmonic ballancer on it. Can I change out the ballancer to a 50oz or do I have to get a 28oz flywheel. The harmonic ballancer is cheaper to get.
harmonic ballancer
There is no way to just change out the Harmonic Ballancer to the 50oz. I already have a 50oz flywheel to make a match set.
The 28oz Flywheel is 400.00 and the 50oz ballancer is 60.00
no you cant just change them out, and a 28oz flywheel is not 400$ take your 50oz flywheel down to a machine shop and tell them you need it to be a 28oz balance
The crankshaft is weight matched/balanced to the flywheel and balancer. A 50/50 balancer/flywheel has a crank balanced for the 50oz imbalance factor, and a 28/28 has a crank balanced for the 28oz imbalance factor. If you use a 50/50 on a 28 balanced crank, it's gonna vibrate like a mother at least, and possibly will snap the crank from the harmonics.
TO the OP....DO NOT POST multiple threads of same subject in various sections...ie you posted this thread in general tech too....please read forum rules. thank you.
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
