Gas & Oil Gauge Problem
Hey everyone i have a 1988 5.0L LX.
The gas and oil gauges on the right hand side of the dash are stuck? the gas needle is above the Full Mark and the Oil needle is at the lowest it can go.
Does anyone know what could be wrong and how to fix this?
kk thanks ill give it a try. im putting the car up on my ramps today for an oil change cause my oil light is on when i start the car up.
ill check out the sending unit at the gas tank and for oil.
where is the oil sending unit located?
Okay ill check out the oil sender wire.
Gas Gauge:
I unplugged the gas sender unit while the car was OFF and then started the car and the gas gauge was still above FULL. When i turned the key and car the car power the gas gauge went up a little higher past FULL.. So it moved like the tiniest bit but it didnt drop to EMPTY
Do i disconnect the wires while the car is running? or did i do it right?
Gas Gauge:
Alright, you are almost better off buying an oil sender because they are dirt cheap. Mine was like 10 bucks from NAPA.
I was under the impression that when you unplugged the sending unit in the tank the needle would raise to above full. I had the same problem and replaced the anti-slosh module on the back of the cluster and will now show an accurate reading when i have less the 1/4 tank but up until then the needle remains at above full. Pretty weird but now i know when my gas is getting low haha.
Okay so i havnt figured out the oil gauge yet. The needle sits at 200 out of 100.. so i dont think thats normal..
Gas Gauge:
I disconnected the sending unit and tested it and its grounded some where!
What do i do!?
Gas Gauge:
What do i do!?
