rattle
you can rent a puller from autozone.
take's like 15min max.
i had a vibration from 65mph and up, felt like the car was going to fall apart. Balenced the wheel's and looked over the hole car, replaced the U joint's.
i replaced the driveshaft with a ford racing aluminum one, and the vibration disappeared.
related to the 4.10 gear's and stock crap driveshaft im sure.
good luck
good luck
Also you might want to grab your driveshaft right behind the transmission. and see if there is any side to side movement. If so the tailshaft bushing is worn out and needs replacing along with the yoke. But as stated above get the Harmonic Balancer replaced ASAP.
i think im going to get an aluminum driveshaft. the tailshaft bushing is shot im pretty sure...because there is a little too much movement for comfort (up down, side to side). ill let you guys know how it goes
AmericanMuscle4.6GT
11-10-2015 02:06 PM
movielover40
09-15-2015 10:37 AM
