Need help with timing...
Alright so under light casual driving my car is fine, but when i floor it, it sputters and then goes, and it does the same thing with revving in neutral too....Does it need to be advanced or retarded?
you should use a timing light remove the pip conecter little plastic thing by the distributor and set it to 13 deg. adv. however what you discribe sounds like you may have bad cap rotor plugs wires ,mabey dist. or coil its hard to say wich of the parts is bad i can only guess without seeing the car
Mods are:
All forged internals
e303 cam
edelbrock victor jr high rise intake
holley 700 double pumper
holley fuel regulator
russel fuel pressure gauge
mallory pro billet distributor
mallory hyfire ignition
mallory pro master coil
ford racing spark plug wires
random dress up parts
all braided fuel line
bbk shorty headers
bbk x pipe
flowmaster mufflers dumped before the rear axle
bbk sub frame connectors
rci 8 gallon fuel cell
holley fuel pump
professional products powerflow fuel filter
traction bars
gay chinese xtuning 5" tach with shift light
t5 trans with drag clutch and hurst pistol grip shifter
and a spooled 8.8 rear end with 3.73 gears
i know some of those mods wouldnt make it run bad, i just copied and pasted the list quickly from my youtube video.
Stock heads?
With a Vic Jr and a mechanical 700 on a very mild 302, it's gonna be more sensitive to minor carburetor problems. If the timing is correct then you might need to make jet and/or accelerator pump changes to the carb.
Alright this car is being weird as hell, when i first got the car, it smoked a little from unburned fuel, my dad played with the timing a little bit and the smoke went away, started the car up yesterday, and i couldnt even stand behind it, it smelled like nothing but fuel, smoking again, and my eyes couldnt stand being anywhere near the car, is this a carb problem?
I think you and dad need to seek the help of a pro. You may not even having a timing problem. Sounds more like the power valve in the carb took a dump. On older Holley carbs one good backfire could wipe out the power valve. I think you guys are in over your head. I can't stress it enough that if you are going to work on your car read up on the component(s) you are dealing with and educate yourself on how it works. Once you understand how something works you can repair it. Until then you will just be throwing parts at your problem and costing yourself more and more problems. Go to Barns and Noble and buy a book on Holley Carbs and study it.
