engines codes
engines codes
ive been reading everywhere and using the search function but just can fine a nice right up on how to pull engine codes, by hand or is there a scanner available for these year stangs?
i have a 1991 5.0 LX Hatch
also for airbag lights, when i was installing my stereo and subs, once i hooked back up the battery i had a airbag light and it blinks 4 times and stops then 4 times and stops and so on...
if anyone has any input on the airbag light please help me and/or pulling engine codes feel free to post as well
this one counts lights also. It shows you how to run several test though. Wiggle test, engine balance, koeo and koer. The better scanners were up around 80 to 100.
Actron is the name of it.
http://cgi.ebay.com/ebaymotors/Actro...motiveQ5fTools
thanks alot for the info man, ok so i know our cars don't have odbii, what do they have and what is the computer called or what not, and scanner type called, im just not clear on this and sorry for being a noob
but i need to learn somewhere also im about to order a chiltons, does anyone reco any other good books?
http://www.equus.com/product_info.ph...gory_id=1_10_3
is a scanner i was just looking at, anyone have any input on this one?
i have a carquest at my work im going up now to ask them if they have something, but if anyone has anything better, just a scanner or tuner that can do it let me know
thanks and sorry for bumping so much im just trying to get something ordered today
all you need is a paper clip to use as a jumper. the diagram shows you how to use the jumper to make the check engine light flash the codes. Its simple.
http://sbftech.com/index.php/topic,2471.0.html
