crank shaft questions
hi, i recently bought a roller block with forged pistons i was going to use stock rods and a balanced stock crankshaft, but im not sure if the 84 HO crankshaft would work in the newer roller block. Would any one know if they could be used together?
thanks marshal |
it should, it is a 50 oz crank, it should have a casting of 2mae on it
As long as it's a 302 crank for a 1 piece rear seal it'll drop right in. Just make sure the assembly is balanced.
ok cool then ill start ording all the engine bearings im running a blown threw set up (10psi) hope fully every thing goes to gether well... and thanks for your guys expertice
